Originally posted by pauly
also, got a new hood, looks fab (in the box) weather has been a tad rubbish. any tips on fitting?
Your going to need some 4mm diameter pop rivets, to replace the ones you have to drill out.
Get a wire coat hanger and make it straight with a tiny hook at one end, use this to pull the tensioning cables through the channels in the hood.
Otherwise tools needed philips screwdriver, 10mm spanner/socket.
Think thats about it.
I expect Adrian P will have some comments about roof fitting, He watched and helped as needed, someone fit his new roof cover last year.
P.s. while you have it all apart if you look at the window edge rubber seals you will notice a hole in the back of them at each end. Thread a 10mm x 10mm x (length of seal) piece of foam pipe insulation inside them, this bulks out the seal and makes the window more water tight.
