Thread: E07A engine variants???
    Jan 2005
    preston
    help E07A engine variants???
    Hi, i'm still having no luck with the tighnerning torques for the main bearing & big end bearing, so i thought i'd see if the ACTY van engine would be the same....??? still drawing no luck, even thou the acty was offically released over here,the service manuals are impossible to find ...
    i've been throu the jap beat service guide, but its just not detailed enough.... or am i missing something??? i'm in the 5-21 section??? is there another section to this exploded view??
    thanks for any help
    There is a separate engine Shop Manual. I have it and home and can give you the specific information you need, but it will be over the weekend at some time thou.
    Ps. Acty with E07A engine was not a UK model only JDM. previous Acty was UK but had 2 Cylinder engine.
    Feb 2007
    Rochester, Kent
    Thumbs up
    A wealth of knowledge as usual
    <<<<<<<VERSION Z>>>>>>
    >>>gone, but not forgotten<<<
    May 2007
    Swindon
    Bearing cap torque settings
    Hi there, two sequences to tighten the bearing cap.
    1st - Snug torque to 3.2kg-m in sequence.
    2nd - final torque to 4.8kg-m in sequence.
    If using original bolts be carefull as when the final torque is appiled the bolts stretch to perform bolt tension and maintain the crank oil clearance.
    Hope this helps.
    32Nm for Bigend bolts
    48Nm for mains. (tigntened in sequence)
Name:	Main bolts.jpg
    Jan 2005
    preston
    Thumbs up Thanks for info!!!!!!!!!!!
    Many thanks Steve M & Rod.... hopefully it will be on the road again soon, unless it needs something else
    wow, blast from the past!
    my dad had a TN360 air cooled T reg from new, then had an Acty van, 600cc twin cyl?
    used to put bag of sand in pick-up to get grip in winter
