Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 50
Thread: Hella HID DOT compliant
  1. #21
    Sep 2010
    Wellington, New Zealand
    Do you happen to have the numbers handy for the stop, tail, park and number plate lights?
    Stop/Tail Lights are the standard 1157 Bayonet Type. I ended up going for 20 Super Bright Flux LED's which do the job fantastically.
    The Park Lights are T10 Bulbs as is the number plate.
    I went for 13 LED T10 bulbs for the park lights. Note: There is a grommet you can remove in the wheel arch to get easy access. (It took me a while to figure that one out!!!!)
    For the Number plate bulb I used a 9 LED T10 (but you could probably get away with less).
Name:	1157 Bulb (Stop Tail).jpg
ID:	2013   Click image for larger version.
Name:	T10 Bulb (13LED).jpg
  2. #22
    Sep 2010
    Thumbs up
    Quote Originally Posted by bigB View Post
    Maybe try the 35watt HIDs also to help with that. 3 times as bright as the 55w incandescent h4h.
    http://page15.auctions.yahoo.co.jp/j...ion/t202316704
    Fantastic, The elusive H4h HID bulb. About as easy to find as rocking horse poo!
  3. #23
    Quote Originally Posted by Obsessive View Post
    Thanks! I was looking at various assortments sold on Yahoo.jp -- most include backup lights but not stop/tail lights. I think bright backups are a good idea too but wasn't sure if they make the LED replacement for the 1157. Now I'll go look around in the shops.
    Steve
  4. #24
    Question: the regular 1157 bulb has a 5-watt and a 27-watt filament, so the brake light flashes much brighter than the running light. Do the 1157-replacement LEDs also do this?
    (Coincidentally on a nice ride back from the beach today I had to jam on the brakes hard to avoid hitting a car in front of me with only one dim brake light.)
  5. #25
    Sep 2010
    Fair question, I had the same concerns before I changed the bulbs. Yes they do shine brighter with the brake applied.
    My tail/brake lights are about the same brightness as the original bulbs. They are certainly more red. The spoiler brake light is still the factory set up so should give you a good comparison. Number plate is now much brighter as you can see.
ID:	2016   Click image for larger version.
  6. #26
    Sep 2010
    Spot the difference!
    Just went outside to swap one over. Left is factory bulb. right is LED bulb.
Name:	1 of each.jpg
  7. #27
    Thanks for the info and photos. Now, one important question (which I would not have thought of until one EBay ad mentioned it) --- are you using red or white LED bulbs for the brake/stop? The ad said you should use red behind a red lens. That makes sense, but so does white.....
  8. #28
    Sep 2010
    I went with the red ones and am very happy with them. I see no reason why the white ones wouldn't work, but felt the red ones would be a safer bet.
  9. #29
    Great - I just sent a mail to an online shop that has all of the LEDs instead of shopping around, and am waiting for a price.
    Next - headlamps.
  10. #30
    Sep 2010
    Cool, I think I'll have to add some H4h HID bulbs to my shopping list soon.
    Remember that the LED bulbs are directional when you come to fit them. I found it rather amusing when all 4 of my dash ones were the wrong way on my 1st attempt! What are the bloody odds on that
  11. #31
    Just a note... If you go with the LED signal lights you will need an "electronic flasher" or some resistor loads as they will flash too fast.
  12. #32
    I was planning to not do the flashers for that reason.
    Re: headlamps - I don't especially want to go with HIDs, so is there some source for the 702K halogen bulbs? Are they the same as H4H??? I could use a bit more light.
  13. #33
    May 2009
    Vancouver, CANADA
    according to bulbs I bought in japan from autobacs, 702k are the same as H4H
  14. #34
    Thanks - I will grab some bright white H4H bulbs today. Is there any trick to replacing them? I assume the alignment remains as-is.
  15. #35
    May 2009
    Vancouver, CANADA
    No trick. Basically, there's a metal hinge that goes behind the bulb. You push inward, then downward and the hinge comes out. Then replace the bulb. There's only one way it will fit.
  16. #36
    Quote Originally Posted by maiku View Post
    Easy - once you know how. Thanks. I got some PIAA Xtreme White bulbs, and I'm eager to see how they go tonite in the rain. At double the price of H4's I hope they will be good!). LEDs are ordered for tail/stop and front marker. I'll forgo the license light, just cleaned the soot out of the lens.
    Steve
  17. #37
    Headlight lens foggy
    New bulbs make the difference between my lenses stick out like a sore thumb.
    There was a thread about using Pikal metal polish on the rear top window. Has anyone ever tried it as a plastic lens polishing compound? I know there are loads of special ones on the market but since I have some Pikal I thought I'd give it a try.
  18. #38
    i had the PIAA's in my old lights before they got trashed - they were great! ive not got round to replacing them yet but i've been meaning to get round to it.
    i used meguirs plastic-X polish on my old lights and it brought them up a treat!
  19. #39
    I think Pikal/Brasso is the same as Meguiars and other polishing compounds, plus some oxide-reducing chemical that makes the rags stink, but it works just fine on plastic. Brilliant! Will do my other car tomorrow.
    Steve
  20. #40
    LED light bulbs
    I installed T10 LED front parking lamps and red 24-LED 1157 replacements for the stop/tail. Granted my old bulbs looked pretty used up, but the difference is amazing.
    I can provide the contact for an excellent LED supplier in Taiwan if anyone desires it.
