Anyone know where to get a timing belt for a '91 BEAT? Also, a cam belt. Mine has 80,000 km. Just want to avoid trouble. Thanx.
Are you in Canada?
In which case I do not know, hopefully another Canadian here will be able to help you.
If I am mistaken and you are from the UK, then a Honda Parts department should be able to get you one.
If not let me know and I might be able to get one from my local parts place and post it to you![]()
Ok thanx. I guess I should try HONDA first.
Does anyone know the spec. on the belts?
Thanx I'll try that whenever I find out where the chasis code is.
Part number for cambelt is 06141-P36-306
Thanx. Owe you one.
