I wonder if I can get the little door pin that turns on the interior light when you open the driver's side door. I think it's a small plastic bit.
Anyone have an idea?
It would be a new switch. CRV 97-01 model ones are the same fitment.
Thanx. I'll look into that. Seems like the best way to alarm both doors.
Is there any other way?
Just add a switch to the passenger side door, run the wire to the drivers side switch. will cover both door then.
Thanx I'll give that a go. Hope to find the switch soon.
I went to scrap yard and got the switch from an old civic most mid 90's Honda used the same switch.
Hope it helps.
Thanx-picked up a switch from HONDA today thanx to Steve M. info.
