The Honda Beat I am getting had a new exhaust put on it a while ago and they removed the catalytic converter but for some reason left the cat sensor connected so the light for that is now always on.
How can i stop the light from being on?
It's gone, it's all gone!!
Do you mean the Orange engine light? or the Red Cat overheat light?
Hi Steve
it's the red light that is always on
You can safely remove the bulb from the instrument cluster for that, the light will come on if the cat has been removed, this light shows cat deteriation and that the emissions are not what it was designed to be, well of course they are if the cat has been removed.
Hi Robin
I had the same problem and have simply removed the light as steve said. A friend of mine recently took the cat out of his 1992 civic, the chap that done dat for him earthed the cat wire off the body and that put the light out on his, maybe that might work for the beat too
Thanks guys.
Can someone give me detailed instructions of how to remove the bulb as i have no idea what i will need to do or how i even get to it
Thanks for your help
I have a similar problem and would also like to remove the bulb - if any info could be provided on physically how to remove the bulb I'd appreciate it.
N
Just drop us a line and I can show you how
Cheers
Oz
Beatless in Bangkok!!
http://www.members.lycos.co.uk/ozsamurai
