Gathers Radio-Cassette Unit
I have a 120 W Gathers that works fine in all respects, apart from the output meters. When inserting or ejecting a cassette, they rotate beautifully, so I assume that the actual display is OK. However, after some initial twitching at switch on, both settle to the 0 position and do not move with the sound output.
Has anybody solved this problem?
