Originally Posted by
unclejemima
Fresh oil for sure. Coolant flush. New Trans oil. That should do the trick
I was going to remove the spare tire...not sure if there is anything else I can really do to remove weight shy of removing the passenger seat.
Will removing the spare tire mess the weight distribution?
This sound intersting. Are you thinking because of the elevation or because of the heat caused by running full throttle for 20 minutes?
Thanks!
Suggest you take the aircon compressor off as it is only dragging power and an extra bit of weight tagging along for the ride, you'll need a smaller drive belt fitted. I don't know the legalities of it where you are but think about ditching the cat and replacing it with a small silencer too! These minor "mods" made a hell of a difference on mine.
