Thread: dash LED bulbs...
    dash LED bulbs...
    following on from another thread, pic of bulbs to replace if anyone else doing it at any future time...
    the one marked in Blue on left is the long tubed bulb holder.
    bulbs are 286 / T5, bulbs only, not with base is better.
    heater display pics to follow when done, along with night pics.
    if i can get indicators working easily without too much work i'll post that as well
    well i've given up at moment with indicators, new relay arrived, still the same.
    LED relay won't work with normal bulbs or LED's, OEM flasher will work with both but with 3 LED's attached they light up but don't flash.
    so, are all 3 pin relays the same pin-out?
    OEM one back in, with just the Amber LED side repeater which works fine, which means i can't be bothered to try the separate resistor route.
    really must get my camera back from France
    will get better pics when there with less light pollution
    9 LED front sidelights
