Hi All, I'll post a fuller description of trip later.
I have an intermittent warning light that has started today. It looks like a large circle inside a set of small brackets. Red in colour.
What is it please?
Dave
What is it please?
Dave
sounds like brake related?
low fluid
ABS sensors etc
handbrake
nothing too important obviously![]()
As above fluid low or handbrake sensor Id say...
Cheers I'll check fluid
Also check your brake pads before topping up your fluid. I've seen situations where the brake pads were worn down enough to lower the level of brake fluid to trigger the sensor.
Wha a massive tit I am!!! A mint stopping handbrake sensor cutting out. Mint eaten, problem solved. Cheers
A tasty solution to a simple problem..
Should this be added to the list of common Beat faults?![]()
